vtdds71 Posted April 16, 2009 Share Posted April 16, 2009 My '72 Z has a 4-speed manual transmission that was recently re-installed after an engine rebuild. New front and rear seals were installed as well as a new rear engine seal. I'm getting some noticeable dripping of gearbox oil out of the weep hole at the bottom of the bell-housing. Any idea what is causing this? What can I do about it? I used Castrol Hypoy 80-90W gear oil. Will the seal of the seals improve by driving the car? Quote Link to comment Share on other sites More sharing options...
zedsn Posted April 16, 2009 Share Posted April 16, 2009 Hi, sounds like your front seal is compromised. You may have damaged it on installation. You will probably need to pull your tranny again and see what the problem is. Quote Link to comment Share on other sites More sharing options...
RUZN Posted April 16, 2009 Share Posted April 16, 2009 Usually when installing the seals I put a bit of tranny magic (sealer) or a good Diff sealant around the seal itself just incase any debri or sand or what have you is still there so it seals no matter what. Buut prolly a seal leak or maybe even the wrong seal was used.. Parts people arent always on their A game =-) Quote Link to comment Share on other sites More sharing options...
