Comrade_Charlie Posted April 16, 2009 Share Posted April 16, 2009 My auto rad got bad, so I installed a 5spd one without a trans cooler thingy built in. Is it safe to install that and just a normal trans cooler? Would I run the chance of burning up my transmission? By the way this is a 1998 pathfinder, I know its not a Z but this is the most knowledgeable site there is! Quote Link to comment Share on other sites More sharing options...
Chaparral2f Posted April 16, 2009 Share Posted April 16, 2009 Using an aftermarket trans oil cooler shouldn't be any problem. Just be sure it is where it can get some air, and if you use the vehicle to tow, get a heavy duty cooler. Joe Quote Link to comment Share on other sites More sharing options...
jasper Posted April 16, 2009 Share Posted April 16, 2009 I would get a NEW RADIATOR. Transmissions are $2000.+ Spend the $150.00 on a quality aftermarket radiator. I would also use the aux cooler in series. Unless things have changed...Transmissions were not a strong point in pathfinders!!! Quote Link to comment Share on other sites More sharing options...
Comrade_Charlie Posted April 16, 2009 Author Share Posted April 16, 2009 nissan automatics suck in general. The front end is smashed, I got the 98 pathy for 300 bucks, the rad was smashed but didnt leak, but the plastic end tanks finally cracked and was leaking... I put a rx7 radiator in there, it fits and works. I want to evntuall use it for towing, ill spend the cash for a good trans cooler. I have a 5spd for this but really dont feel like wrenching on this thing much. I just know in my maxima that was auto, I put the trans cooler after the radiator got the bulk of the heat out... im putting it in a big open spot in the front end. the frame isnt dmg, but the rad support is bent up enough to not fit a path radiator or condensor. but I dont have the cash to fix it, and cant bring myself to part it out. Im using a trans cooler from an explorer from a junkyard, I was thinking about using 2, side by side, not front and behind, so they both can get cold air. I really cant afford any thing over 10-20 bucks since im trying to get my 300zx back on the road. Quote Link to comment Share on other sites More sharing options...
