Livin9it2up1 Posted April 18, 2009 Share Posted April 18, 2009 I have a Datsun 280z with a turbo l28 swap (just got running yesterday) and went to bleed out the clutch, and when i went to loosen the bleeder screw it sheared right off, so i replace the slave Cylinder. So today i again went to bleed the clutch with the new slave cylinder and i couldn't get it to move the clutch for more than a 1 millimeter. the master cylinder looks fairly new, an i couldn't find any leaks. And the clutch pedal was fully adjusted out. Any ideas what the problem could be? Quote Link to comment Share on other sites More sharing options...
bigal Posted September 12, 2009 Share Posted September 12, 2009 do you have pressure @ the slave? you may need a longer push rod Quote Link to comment Share on other sites More sharing options...
