shawn83zxt Posted April 18, 2009 Share Posted April 18, 2009 Hows it going guys? I haven't posted in a while so I'll give you an update on my project. 350/TH350 Trick Flow 23 degree aluminum heads Scorpion 1.5 anodized roller rockers Edelbrock performer RPM intake Holley 3310 vacuum carb 750cfm Comp Cams 268XE cam/lifters JTR block huggers MSD pro billet distributor MSD 6AL box SS brake lines Engine is in and mounted, the trans crossmember is assembled, but I've yet to drill into the trans tunnel. The stock TH350 trans mount does not match up to what I was supplied with from JTR, I'm going to drill so that the two will mate up. After thats done I will be able to measure the correct driveshaft length. Now onto the part of the project I am tackling currently. The MSD 6AL needs a switched 12v source. What are you other MSD 280zx swappers using for this? I've relocated my battery to the rear, so my box is located on the firewall where the battery once was. Also, pictures of your setups would be great, and if possible, may I see your starter wiring? I'm using the wire from the stock datsun starter, but it just doesn't seem to want to crank! I'm currently searching the archives, but I'm rushing and trying to get this done for the West Coast Z Nationals! Any input or comments will be appreciated, thanks guys! Quote Link to comment Share on other sites More sharing options...
