FAN SHROUD.
Guest zfan
I'VE JUST INSTALLED AN ELECTRIC FAN IN MY Z.
IT IS A 16 INCH, PULL NOT PUSH. I TOOK THE OLD SHROUD OFF WHEN TAKING OLD STOCK FAN OFF, PROBLEM IS IT SEEMS TO BE RUNNING VERY HOT, MORE SO THAN BEFORE.
DID I MAKE A MISTAKE WHEN REMOVING SHROUD, I CAN EVEN FAB MY OWN SET UP IF NEED BE.
ANY IMPUT WOULD BE APPRECIATED!!
THANKS MIKE
Guest Fast Frog
zfan:
I would definately fab some kind of shroud if you can. I got several Zs and here in Grand Junction. In the summer (like as we speak), the temps get into the low 100's. I have noticed 20-30 degrees cooler engine temps with a shroud over no shroud. Also your new 16" fan may not be as efficient or flow as much cfm as the stock setup.
Rick
