1 fast z Posted April 22, 2009 Share Posted April 22, 2009 Ok, so I have been talking to matt, at DIY, and he has helped alot. He says that since I was setup for EDIS before, the only thing I have to do is take the jumper that was from tachselect to optoin, that it now needs to go from tachselect to VR in, and that is it for chaning things, except for connecting the BIP's to R26, 27, 29 and MT setting changes. But as per this page http://www.diyautotune.com/tech_articles/trigger_wheels_overview.htm It says this: Build the VR conditioner circuit, as described in Step 51 of the MegaManual. All our preassembled Megasquirts with the V3.0 or V3.57 board come with this circuit installed. Jumper TachSelect to VRIN. (V3.57: Set JP1 to the 1-2 position.) Jumper TSEL to VROUT. (V3.57: Set J1 to the 3-4 position.) You may need to adjust the VR trim pots, R52 and R56, when this is installed on a running engine. A usual base setting is to turn them all the way counterclockwise. Jumper IGBTOUT to IGN to send to IGBT ignition coil driver signal out of pin 36 on the DB37. (not needed on a V3.57) Cut out R57 if fitted (This won't be there on my units, though.). So do I also need to jumper Tsel to VR out? Also, I have a jumper from IGN, to S10 currently, but DIY's site says to jumper IGBOUT to IGN? Any help guys? Quote Link to comment Share on other sites More sharing options...
