Guest cesarnono13 Posted May 5, 2009 Share Posted May 5, 2009 I wanted to make sure that the way the coil is placed is the right way. as far as the negative and positive are concerned! thanks in advance guys! its a 74 1/2 260z. http://img14.imageshack.us/img14/7092/img5161s.jpg Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted May 6, 2009 Share Posted May 6, 2009 Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted May 6, 2009 Share Posted May 6, 2009 Hard to tell by the pic if its wired correctly, see the diagram Quote Link to comment Share on other sites More sharing options...
burninator Posted May 7, 2009 Share Posted May 7, 2009 Hard to tell from the picture, but my car has a condenser hooked up to the coil. It looks like you have the condenser hooked up on your coil negative side. Mine is hooked up on the positive side. My understanding is that not much goes through condensers so it would probly run either way, but I think having it on the positive side is correct. Quote Link to comment Share on other sites More sharing options...
burninator Posted May 7, 2009 Share Posted May 7, 2009 I looked it up in my Haynes manual and the negative side goes to the distributor, the positive side goes to the ignition switch. Wiring it backwards might let the car run, but it could lose 60% spark efficiency. Hope that helps. Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted May 7, 2009 Share Posted May 7, 2009 Yes, the condensor goes to the negative side of the coil. Quote Link to comment Share on other sites More sharing options...
