Tps ohmeter adjustment
I replaced my tps sensor and im having issues adjusting it with an ohmeter and I went searching threads but no one really touched base on adjusting tps with and ohmeter. Could somone give me some tips on what signals the tps sends out on what prongs for idle cruise and wot?
The center and rearmost terminals should have continuity only at dead closed throttle.
You should lose continuity with only the slightest movement of the throttle but let it move a few thousandths before you lose continuity or you could end up with it coming off and on a billion times per second with engine vibration.
On the non turbos, you have three terminals and you get idle on the rearmost two and you also get "full throttle" coming in at about 3/4 to 7/8 of full throttle body opening.
On the non-turbos the ecu only uses the idle.
There are two microswitches inside it so you won't getting a change in resistence but rather on or off depending on throttle position.
