fl327 Posted February 14, 2001 Share Posted February 14, 2001 hey guyz and galz, ive finally worked almost all the bugs out of this z v8 drivetrain, to the point where i basically did the conversion all over again, now i am going to start up on the electrical side, which i hate hate hate ok here it is, when i turn the headlights on the left light shines great, but the other one only bearly comes on, but its on ive tried different light housings and changed teh fuses, that is about the extent of my electrical expertise, does anyone know what this could be, and one other thing, the lights do come on both good every once in a while...any help would be great thankz FL 327 Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted February 14, 2001 Share Posted February 14, 2001 It's either a bad ground, or the switch isn't making contact, or a bad contact because of corrosion, on that side. ------------------ http://members.tripod.com/~SnowSurfer/mikekz1.html Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted February 14, 2001 Share Posted February 14, 2001 I had the same problem with my headlights in my 71 240. Was combo bad ground and corroded socket plugs. Hope this helps. Z/Fan..Mike Quote Link to comment Share on other sites More sharing options...
Guest harth Posted February 15, 2001 Share Posted February 15, 2001 I had the same problem on my 280, it was one of the wiring harness plugs in the glove box area, I was able to wiggle them around to find the right plug, it was just a little corroded Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 15, 2001 Share Posted February 15, 2001 Do my headlight harness mod - I'm telling you that you'll be MUCH happier! BRIGHT lites and no more worries about burning up th ewiring if you switch to higher wattage bulbs. I see you've got a post above concerning the nice blue looking bulbs - you'll want the harness for that - trust me Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted February 16, 2001 Share Posted February 16, 2001 Read my article - the Painless harness is not what you want unless you don't mind wasting a few bucks. It's what I used before I knew better - the MAD harness is cheaper. I'm trying to save ya' some money is all Quote Link to comment Share on other sites More sharing options...
fl327 Posted February 16, 2001 Author Share Posted February 16, 2001 thanx guyz, ill check into the painless wiring harness for sure really soon, i really need that, man those switches are like 100 a pop, man oh man oh man, yo the blue lights are dot approved, i dont know, if i get a fix it ill fix it...... Quote Link to comment Share on other sites More sharing options...
