TheNeedForZ Posted May 14, 2009 Share Posted May 14, 2009 Greetings, I have a question about using a 4WD 4L60E (from a 2004 GMC Sierra) in a 2WD application (my engine is a 98 Camaro LS1, Car is a 260Z). Is the 4L60E used in the 4WD application (trucks) basically the same as the 4L60E used in 2WD application? or are they totally different animals ? I do understand that they share the same bolt pattern, I am not sure if that's where the similarity ends, but I hope I can use the 4WD auto trans in a 2WD application without too much modification. TheNeedForZ Quote Link to comment Share on other sites More sharing options...
AK-Z Posted May 14, 2009 Share Posted May 14, 2009 I would assume that the 4wd version would be longer because of the transfer case. I would think you can still run it, if you just kept in 2wd, but then it would be heavier and fitment in tunnel would be awfully tight. Quote Link to comment Share on other sites More sharing options...
John Scott Posted May 14, 2009 Share Posted May 14, 2009 Probably different output shaft and rear housing. I did this on my first 700r4 out of a 4x4. Best to search google. Quote Link to comment Share on other sites More sharing options...
nick77 Posted May 18, 2009 Share Posted May 18, 2009 they are the same except the output shaft in the 4wd is shorter than the 2wd and you would need to find an extention housing, unfortunatly you need to tear the whole tranny apart to change the output shaft, ive had to do swap a 4wd to a 2wd once Quote Link to comment Share on other sites More sharing options...
