strange brakes
Sounds like a bad master cylinder, or the other common suggestion is the reaction disk. Are your brakes all bled properly? the reason you get good pedal feel when the car is off is you are using the remaining vacuum in the booster. My cadillac had this problem, changed out the master cylinder, no more problem. Look for leaks under the car, by the wheels and all the lines before you start going crazy.
