jakeoster Posted May 27, 2009 Share Posted May 27, 2009 Im very close to getting my RB25 to fire for the first time. Im getting it to crank over but it seems like its not getting any fuel into the fuel rail. I may not be priming it right because when I unscrew that bolt on the fuel rail nothing comes out of it, no pressure or fuel. However when I pull the fuel line off where it connects pressurized fuel comes out. Anybody have any insight into this problem? Edit* Ive been going through the forums and really havent found any RB first start guides etc. Im new to the whole first start procedures on a fuel injected engine (my Crx project before this was carbureted) anyone got any advice? Quote Link to comment Share on other sites More sharing options...
dwarlick Posted May 27, 2009 Share Posted May 27, 2009 Be sure you fuel pump is hooked correctly. I had this same problem. In my case the polarity on the fuel pump was reversed and it wouldn't pump. Also double check the fuel is going the right direction according to the arrow on the fuel pump. You have gas in the tank right? What about a fuel filter. Just some ideas. Good luck. Danny Quote Link to comment Share on other sites More sharing options...
Canadianz Posted May 27, 2009 Share Posted May 27, 2009 So if Im reading this correctly you have pressure before the fuel rail... the side nearest to the fire wall but nothing is flowing past that ? Make sure the lines are hooked in correctly. The return line is at the front of the block and it comes off the fuel pressure regulator, which looks like a little bumpy fitting with a vacuum lime off it. The fuel rail feed is the open end at the fire wall side. If your trying to run fuel backwards through the FPR that might cause it. Other wise try putting a pressure gauge at the end of your feed and see what kinda of pressure the line is at... Keep working forwards until you find the blockage. As mentioned in the other post you might have the pump hooked up incorrectly. It should have a positve, negative and a control wire to the ecu. If you didn't hook up that one the fuel pump might not run right. Good luck ! Chris 1 Quote Link to comment Share on other sites More sharing options...
jakeoster Posted May 27, 2009 Author Share Posted May 27, 2009 Ok thanks guys, I actually had the lines reversed and the fuel was going entering the return. Now that I got that that sorted I realized that I was getting no spark. I took the coil out and double checked it and it is in fact not sparking. Anyone have this problem? Quote Link to comment Share on other sites More sharing options...
dwarlick Posted May 27, 2009 Share Posted May 27, 2009 However when I pull the fuel line off where it connects pressurized fuel comes out. Anybody have any insight into this problem? Missed that part of the post. Sorry. Quote Link to comment Share on other sites More sharing options...
jakeoster Posted May 27, 2009 Author Share Posted May 27, 2009 Well sorted out some problems, however the computer I had was dented in a bit. Just so happened to be touching the circuit board and fried it. Opened it up and its wasted. Anyone happen to have an RB25 V.2 Computer? EDIT* bought one off ebay for $150 Quote Link to comment Share on other sites More sharing options...
Careless Posted May 27, 2009 Share Posted May 27, 2009 sounds like a ball is rolling downhill here. i hope the ecu is the last of it. been in this situation too many times! Quote Link to comment Share on other sites More sharing options...
jakeoster Posted May 28, 2009 Author Share Posted May 28, 2009 Want any fish with those fried chips? If your ECU is dented in even a little make sure you check it, it will short out. Quote Link to comment Share on other sites More sharing options...
Canadianz Posted May 29, 2009 Share Posted May 29, 2009 Sorry bout the ECU .... Glad though that you got your fuel issue sorted out ! Keep throwing time at it and it will be done soon! Quote Link to comment Share on other sites More sharing options...
jakeoster Posted May 31, 2009 Author Share Posted May 31, 2009 Yeah Im just waiting on the ecu i ordered and BOV. The wait is killing me! Quote Link to comment Share on other sites More sharing options...
