Arif Posted May 28, 2009 Share Posted May 28, 2009 I've got a 280zx tranny hooked up to a L28et motor. When I get on it in third gear the shifter pops out of gear. It only happens in third gear so I'm wondering if something is out of adjustment. Quote Link to comment Share on other sites More sharing options...
Arif Posted May 29, 2009 Author Share Posted May 29, 2009 Any ideas???? Quote Link to comment Share on other sites More sharing options...
woldson Posted May 30, 2009 Share Posted May 30, 2009 Keepers (I believe that is what they are called) are shot. I have been told that leaving your hand on the shifter put ware and tare on them. Quote Link to comment Share on other sites More sharing options...
Whittie Posted May 30, 2009 Share Posted May 30, 2009 Arif, I have a standard 260Z box with upgraded new-model synchro's, and when the gears are worn, i have this exact problem. Happened on about 3 gearboxes now. Current issue is falling out of 5th under power. previous was 2nd when coasting at +4000 rpm, first was 1st gear under power. It could be a similar issue for you, or the keepers as woldson says. Either way my guess is something is worn and has worn gear edges that dont 'grab' anymore and is letting the 'box fall out of gear. Quote Link to comment Share on other sites More sharing options...
Arif Posted June 2, 2009 Author Share Posted June 2, 2009 Thanks guys. I'll check out both possibilities. Quote Link to comment Share on other sites More sharing options...
