vg30dett horizontal mesurement
Guest d21
hey, does anyone know or could mesure the widest part of a vg30dett including turbos that would be a great help and what is the length of the motor as well?? thanks in advance
If your trying to fit it into a HB you will have a very hard time doing it in a 2wd. The turbos hit directly on the frame rails, you can notch them to clear the turbos but it will make it very difficult to work on. They only clear the frame rails in the 4wd's due to the raised engine height. All I am saying is you can have the accurate measurements but its going to hit either way and you will need to cut. peace.
