How to adjust float on 3 screw carb?
at-jefft
Hey, I removed the 4 screws on top of the float chamber cover and thend tried to remove the cover and float but there is a piece of the carb body that prevents the cover from lifting off. How do I adjust the float level if I can't remove the float chamber cover and float arm? Thanks in advance, Jeff
I can take some pics if need be, but I can't imagine nobody has delt with it before.
