Stock fuel feed enough for 302?
I was originally going to use the drain plug as the feed but I can't figure out how I'm going to do that since the drain plug uses only 1/2 size bolt. So my next question is will the stock feed be enough? For a 300whp carb 302? Btw which is the fuel feed on the tank? I took it down a while back and forgot. This will go on a early 260z with 1/2 aluminum lines
  • 1 month later...
Are you talking about the feed nipple? I am running 5/16" hose off of the nipple to the pump, then -6 from the pump to the rail. I was also running this setup with my carb and it ran fine. If you're running 1/2" hard line, you should be just fine at 300 whp.
