Guest Zpeed Posted June 22, 2001 Share Posted June 22, 2001 okey when i go to turn i flick the turn signal stick up and i turn, then it doesn't flick back to turn off, i hope you understand what i mean was this normal in Z's i'm not sure, but if it isn't, wat would i have to do, i've opened the switch up before but havn't seen any major problems with it ,i have seen that the joint is a little loose, but that wouldn't be causing it i would think, maybe a spring or something, i have no idea... thanks Quote Link to comment Share on other sites More sharing options...
Owen Posted June 22, 2001 Share Posted June 22, 2001 I don't remember if the Z had this, what year was it? I know in my other car there is a tooth on the steering wheel hub that disengages the turn signal when its flicked on. Oh, I know, my car didn't have the stock steering wheel in the first place. Take off the wheel and flick the switch, there might be some kinda plastic switch or arm that sticks out. When you turn the wheel back to straight, something should hit this and disengage the turn sig stick. Owen Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted June 22, 2001 Share Posted June 22, 2001 I seem to remember there being a rollpin in the steering wheel hub that makes contact with a fork when you put on the turnsignal. The fork gets moved down and clipped by the rollpin when the wheel is turned, turning it off. At least thats the way I remember it, been a while since I had the wheel off, and even longer since the stock wheel. Regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Zpeed Posted June 22, 2001 Share Posted June 22, 2001 well its a 76 260z aussie model, i don't have the original steering wheel on... i do remember, seeing a fork or something like that.... might be that. i'll go have a look. but the stock steering wheel that i have got is all rotten, then rubber is rotten, i'll go have a look at it now... but can't go test it... cause it on the jack stands... maybe someone else knows... Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted June 22, 2001 Share Posted June 22, 2001 Ya it's definitely that roll pin that Lone described that sticks out of the hub of the wheel. It contacts that fork in the column. Quote Link to comment Share on other sites More sharing options...
