Air con / heater bulkhead fittings setup?
Savage42
Hey guys! I'm going to start installing the dash & climate controls into the 280Z-06 and was wondering if there is a setup and/or place that sells bulkhead fittings to use at the firewall to allow the use of 90 degree fittings to route the lines more cleanly. Any ideas or input are appreciated.
Yep I can get these for you #10 / #8 / #6 tube oring style. I have the fittings with barbs for heater hose. Or normal (tube - O) A/C fittings will screw right on to these. They are Male insert O-ring on each side.
If you need help sourcing A/C hose, other fittings, or any sort of HvAC parts let me know!
