mark Posted June 21, 2009 Share Posted June 21, 2009 What are you guys using for header gaskets on ported heads? I've always used the stock gasket on my stock heads but the stock gasket blocks the larger ports on the new heads. Any ideas? Thanks. Quote Link to comment Share on other sites More sharing options...
jt1 Posted June 22, 2009 Share Posted June 22, 2009 Quote the larger ports on the new heads. ??????????????? jt Quote Link to comment Share on other sites More sharing options...
mark Posted June 22, 2009 Author Share Posted June 22, 2009 It's the while I'm at it syndrome. The engine was out of the car and I couldn't leave it alone no matter how hard I tried. Quote Link to comment Share on other sites More sharing options...
jt1 Posted June 22, 2009 Share Posted June 22, 2009 I fully agree. One time a rear main seal turned into almost a completely new motor for me. As it should have. jt Quote Link to comment Share on other sites More sharing options...
mark Posted June 26, 2009 Author Share Posted June 26, 2009 Just a follow up here. My heads are casting 243 with a CNC port job. I was trying to use the stock manifold gaskets that came with my 2002 F body ls1. The gasket blocked part of the exhaust ports. On recommendation from Jeff Creach at Carolina Auto Masters I ordered GM part number 12612944. It seems GM redesigned these gaskets to accommodate the larger port sizes. This is now the only manifold gasket GM makes for the LS1 motors. If fits perfectly with no restrictions of the exhaust ports. Quote Link to comment Share on other sites More sharing options...
