smithmiller6 Posted June 22, 2009 Share Posted June 22, 2009 Hi I have a miller 185 mig,is it possible to weld alum? If not what da ya suggest without purchasing a tig. Thanks Quote Link to comment Share on other sites More sharing options...
Challenger Posted June 22, 2009 Share Posted June 22, 2009 I have yet to try it on my hobart but from what Ive read here you can do it with different wire, gun and gas. Cant provide any more specifics but you might try googling "welding aluminum with a mig." Quote Link to comment Share on other sites More sharing options...
AK-Z Posted June 22, 2009 Share Posted June 22, 2009 http://forums.hybridz.org/showthread.php?t=147521 read Quote Link to comment Share on other sites More sharing options...
BQR280Z Posted June 22, 2009 Share Posted June 22, 2009 Yes you can weld aluminum just fine with your Miller 185. Add a Miller spool gun kit and a tank of argon and you are good to go. The soft aluminum wire will not push through the standard wire feed hand torch. The spool gun only pushes 4" or so and works fine for up to .25 alum. (multiple passes) Bill Quote Link to comment Share on other sites More sharing options...
randy 77zt Posted June 23, 2009 Share Posted June 23, 2009 i tried installing a new liner and running aluminum wire in my mig(thermalarc 180) the wire wont pass through the liner-it bunches up at the drive motor.i used a spool gun in a welding class i took.it was pretty easy. Quote Link to comment Share on other sites More sharing options...
