240z Key Code
While trying to hunt down a short in my heating system, I found the tag on the inside of the glove box which gave me the code: 4647 - in reference to the key code for the ignition/doors/rear hatch.
My question is: Does this seem to be a valid code, or should I pull the ignition cylinder and search there. I'm 90% certain that I have the original locks all around.
~Thanks
The code 4647 is only part of it. Preceed that with an "M" and it would be correct. It should also NOT be on the ignition lock, so don't bother pulling it. It WOULD be on the passenger door lock though.
Code M4647 was used from 1970-1982 for Nissan/Datsun 6 cut keys. 4647 (by itself) represents a key code for Nissan/Datsun 8 cut locks from 82 forward. Nissan stopped putting key code tags on glovebox doors in 1986.
Hope that helps.
Warren
Hope that helps.
Warren
Wow, that helps more than you could know.
~Thanks
