DevilZX Posted June 24, 2009 Share Posted June 24, 2009 I just put in a replacement transmission (BW T5) and now it has this violent side-side shake in the shifter. This only occurs in 3rd gear and if I push the shifter forward farther, it seems to stop. The only thing different from the swap is the tranny, the tranny cross member plate (attaches across the cross member on the front side) was removed. I think that the driveshaft may be 180* off (unsure if this is the problem but solved vibrations on previous vehicles). Quote Link to comment Share on other sites More sharing options...
aarang Posted June 26, 2009 Share Posted June 26, 2009 Maybe the plastic cup didn't get back onto the end of the shifter? I have done that before and had the same result. Quote Link to comment Share on other sites More sharing options...
DevilZX Posted February 10, 2010 Author Share Posted February 10, 2010 Still no fix but I'm getting a new clutch and flywheel put in soon. I will have them check straightness of the shafts in the transmission also. I'll update if this cured the problem once finished. Quote Link to comment Share on other sites More sharing options...
Kash Posted February 11, 2010 Share Posted February 11, 2010 I have trans in great condition for $120 if you need a replacement. Quote Link to comment Share on other sites More sharing options...
DevilZX Posted February 12, 2010 Author Share Posted February 12, 2010 Got the unit out today. The input shaft has about 1/8"-1/4" of play in all directions besides in/out. Got a new bearing on the way. I may have to take you up on this offer. T5? Could you get a shipping quote to 55376 for me please? Quote Link to comment Share on other sites More sharing options...
