Another Dizzy Question
zfreak77
Not Dizzy as in falling over or blonde LOL. How many volts are on the three wires coming from the dizzy on a 76 280z going to the transistor ignition module or ohms if any. Need help with getting this puppy running. It has a newly rebuilt engine it's a f54/p79 combo with what I beleive is a stage 2 or 3 cam. It will start when its cold but wont run good. its got a skip and after it warms up it's extremely hard to start and will flood out. It will not idle very long either. All the vacum lines are new, no holes or cracks in the boots, new plugs. I am debating on 280zx ignition conversion but not sure if thats going to make a difference. tdc is correct and oil pump shaft is in the correct position. I'm baffled so any help would be greatly appreciated. Thanks
