HIWAY ONE Posted June 30, 2009 Share Posted June 30, 2009 I bought a pair of used axles a few years back while accumulating parts. I also have Ross' conversion kit installed on my car. I've just pulled out the axles to test install. Question1, how far in does the axle shaft go into the diffy? Their are like 3 sections to the shaft end, first the splined section, next a section with diagonal grooves, then a thicker section up to the housing cover. I can get it in to the first two sections where the smooth thicker piece of the shaft is showing. Does it go in further where the housing cover should butt up againt the side of the diffy? The picture in the FSM looks like maybe only the spline section goes in.... Question 2, do I need a circlip to hold the shaft into the diffy? Thanks for any help guys, this is probably the longest Z on jackstand project ever (28 years). Quote Link to comment Share on other sites More sharing options...
rztmartini Posted July 2, 2009 Share Posted July 2, 2009 the axel should snap into place, there is a ring inside the diff that snaps onto the groove on the splines. you gotta kinda slam it in there, but the CV cover should be against the diff housing. in other words, you shouldnt be able to see any shiny parts. Quote Link to comment Share on other sites More sharing options...
HIWAY ONE Posted July 2, 2009 Author Share Posted July 2, 2009 Thanks, I'll give that a try. Quote Link to comment Share on other sites More sharing options...
