temperature sensor going bad?
PanzerAce
So my coolant temp readings have been acting really weird lately. It'll climb normally to operating temperature, but once it gets there, it almost drops right back down to about 120 degrees on the guage. Even if the engine sits for awhile to let the heat soak into the coolant, the dial never moves more than 3-5 degrees off of 120. I'm thinking (based on how the car is driving/idling) that it's just the temperature sensor that is off (or the wiring has started grounding on something maybe?), but is there anything else that could cause these symptoms?
