alternator charging but battery still going flat
my car: 280zx 1978
hey
my battery drains flat in abuot 4 days of not driving it
i found that something is draining 0.26 amps from the battery constantly
ive then checked alot of the wiring in the car and the drain is not through the fuses
its from a cable which is plugged in to the alternator
the alternator seems to still charge my battery when i drive around but with this on and the car stopped its constantly draining 0.26 amps.
i think this is the cable which charges the battery or sumfin, but i duno
can anyone tell me what the top cable plug from the alternator is???
and is there a short in my alternator or sumfin?
should i buy a new one?
Is your alternator consist of an internal voltage regulator or an external regulator mounted somewhere on the inner fender or the firewall.
When Voltage Regulators go bad they sometimes will give the symptoms your desribing, AKA: The alternator gauge indicates it's charging while the engine is runing but while the car is parked it will drain the battery.
Before replacing anything make sure all your grounds w/in the ignition/charging circuit have good clean contact surfaces & their wires have not become corroded or rusted.
Kevin,
(Yea,Still an Inliner)
