alsil Posted November 6, 2001 Share Posted November 6, 2001 I have a '71, and the wiring harness is a mess. I have a good one from a '73, how compatible is it? I would like to just plug it in, but I am not sure what differences there are. I know they have to be similar. Any body know? Thanks Al Quote Link to comment Share on other sites More sharing options...
fl327 Posted November 6, 2001 Share Posted November 6, 2001 i dont think there is, and if it is different, its not that different, most of it should bolt up, the other stuff you can run direct to trace where it should be installed on the fusebox. Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 you will find differences in the alternator wiring I believe.....but I am sure there will be a large difference in the wiring for the tach. I you are a V8er you will find something on this in the JTR manual. I will try to find for you. Jake Quote Link to comment Share on other sites More sharing options...
alsil Posted November 6, 2001 Author Share Posted November 6, 2001 Alternator wiring doesn't matter to me, I have the stock 140amp Ford Alternator on mine with it's own harness. And as far as the tach, that's got it's own harness too. I wasn't about to mess with the mess that is my wiring harness to try and make it work. If that's the differences, then I should be OK. Thanks AL Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted November 6, 2001 Share Posted November 6, 2001 Nope, but my Nike tastes like shit. The issue I had in the back of my mind has nothing to do with your question. oops Jake Quote Link to comment Share on other sites More sharing options...
alsil Posted November 7, 2001 Author Share Posted November 7, 2001 no problem Quote Link to comment Share on other sites More sharing options...
