240Z vs 510 stub axle difference
sr71sss
I tried to search for an answer and came up with nothing yet so I figure I would ask out loud.
Im looking to use some redrilled stub axles I have presently mounted on my 510. Can they be swapped into a 240z since I don't want to waste the arp studs that are mounted already on my 510 stub axles.
The car had some junky 4 to 5 lug wheel adapters that just dont look safe to run for more than a short trip around the block and I want to drive her around now since I have her running so well after many years of sitting inside someones garage for the past 14 years, mind you the car has imsa flares with 12" wide wheels with a 3.5" backspacing so I will need at least a 1 inch wheel spacer to kick out the wheel to fill the flares
conrad
