nelson rodriguez Posted August 6, 2009 Share Posted August 6, 2009 need to locate source of these wires, they are causing me problems. for some reason they are not getting any current and they are giving me starting problems. what is the green wire and what is the red +,-, please advice. oh and it's a 77 280z. Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted August 6, 2009 Administrators Share Posted August 6, 2009 Those wires aren't supposed to 'get any current'. They run from the VR sensor (variable reluctor) in your distributor, straight to the ignition module (passenger side kick panel). The VR sensor is the 'trigger' for your electronic ignition. Quote Link to comment Share on other sites More sharing options...
nelson rodriguez Posted August 7, 2009 Author Share Posted August 7, 2009 ok thanks. i think it is sticking, why would it do that? Quote Link to comment Share on other sites More sharing options...
Administrators RTz Posted August 8, 2009 Administrators Share Posted August 8, 2009 ok thanks. i think it is sticking, why would it do that? What is sticking and why do you think it's sticking? Quote Link to comment Share on other sites More sharing options...
nelson rodriguez Posted August 16, 2009 Author Share Posted August 16, 2009 well i havent had any problems since. well my car would not turn on unless i poked at those wires with a tester. the pointy one that you clip to a ground and the light comes on. so far it has worked without doing that. thanx i havent checked my emails since. Quote Link to comment Share on other sites More sharing options...
