z31trackcar Posted August 12, 2009 Share Posted August 12, 2009 First off, I've searched and read all stickied threads. This is a pretty unique build that I'm getting into. I'm looking to swap an RB20 into a Z31 (nothing unique there), but I'm looking to do so with as little of the original chassis wiring as possible. This is not going to be a street legal car. It is going to be a purpose built race car for road racing. Ideally, I would like to have the ECU only connected to the engine and transmission sensors/plugs/injectors/switches. The only exception, of course, would be the ignition switch. I need to know if this is even possible. I'm new to Nissans, so bear with me. I will not be using the stock gauge cluster or anything else like that. I basically only want the ECU to run the engine. Is that possible? Quote Link to comment Share on other sites More sharing options...
Careless Posted August 13, 2009 Share Posted August 13, 2009 Yeah, it's possible. make a break away harness for the gauges and such, and you'll be ok. Quote Link to comment Share on other sites More sharing options...
z31trackcar Posted August 13, 2009 Author Share Posted August 13, 2009 Sweet! I had already started reading about stand alones and what a relief that I won't have to deal with that. Thanks for the help. Quote Link to comment Share on other sites More sharing options...
fast-datsun Posted September 11, 2009 Share Posted September 11, 2009 WE offer a STL wiring conversion that requires on the hook up of 4 wires to make the motor run. Quote Link to comment Share on other sites More sharing options...
