Noddle Posted August 14, 2009 Share Posted August 14, 2009 Hi, I was doing some 3rd gear pulls, tuning my MS II system, and this is what happened, 7K, 15psi Originally I though it was a manifold gaskets, but once I got it pulled down, I saw the head gasket hanging out the side of the block, But I've had some fun with it, N/A L24, dished piston, N47 head 440cc injector intercooled EDIS, Nigel Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 30, 2009 Author Share Posted August 30, 2009 The weather cleared up for a few hours today, so I had a chance to pull it down and have a look, It looks like it been detonating for a while, the AFR is pretty good, but I assume my timing is way to high. at least it's giving me a chance to fit my EGT Nigel Quote Link to comment Share on other sites More sharing options...
slownrusty Posted August 30, 2009 Share Posted August 30, 2009 Nigel - Why were your pulling your so high (7,000 rpm), do you have a cam in your car? Also if your AFRs were fine why would it be detonating...confused. Your MS can pull timing? Yasin Quote Link to comment Share on other sites More sharing options...
Noddle Posted August 30, 2009 Author Share Posted August 30, 2009 slownrusty said: Nigel - Why were your pulling your so high (7,000 rpm), do you have a cam in your car? Also if your AFRs were fine why would it be detonating...confused. Your MS can pulltiming? Yasin Hi here's a picture of the log at the time I blew my head gasket,the second peak is where it let go And my timing table. Nigel Quote Link to comment Share on other sites More sharing options...
Noddle Posted September 7, 2009 Author Share Posted September 7, 2009 Hi, It's up and running now, but after looking at my spark table and seeing high degrees at low RPM, I decides to make some changes, this is my new table, any comments are welcome, at some point I will need to go to a dyno to have it done professionally Nigel Quote Link to comment Share on other sites More sharing options...
