monsterz Posted August 17, 2009 Share Posted August 17, 2009 can anyone help me out my 240zturbo with z31 ecu when the motor warm up ecu get so hot? please!!! Quote Link to comment Share on other sites More sharing options...
MikeBZ Posted August 18, 2009 Share Posted August 18, 2009 Where is the ECU located in the car ? Make sure its away from any direct heat source and air can flow around it You could also take the cover off the ECU and inspect the boards inside, make sure there isnt a bunch of dirt or other crud in there.. Quote Link to comment Share on other sites More sharing options...
monsterz Posted August 19, 2009 Author Share Posted August 19, 2009 thanks mikeBZ but my ecu and harness still out side. i mean i hook up all the wires but ecu is on top of the air intake grille. and if i throttle pass 3500rpm i let go the throttle than the motor turn off by it self. i also have all my 3 ecu (z31) it happen the same. Quote Link to comment Share on other sites More sharing options...
