terrya Posted August 19, 2009 Share Posted August 19, 2009 Need to remove trim for body work. The trim is the one that runs along top of the car and ends at the bottom corner of the rear side window. If anyone knows how to remove this,, it would be greatly apprectiated. Looked in the fsm but it did not seem to be there. thanks! Quote Link to comment Share on other sites More sharing options...
terrya Posted August 30, 2009 Author Share Posted August 30, 2009 "Bump" Any ideas! Don't want to ruin it, doing it the wrong way. Quote Link to comment Share on other sites More sharing options...
datsun79z Posted August 30, 2009 Share Posted August 30, 2009 Terrya; The trim you are referring too is held on by sheet metal screws which are inaccessible without first doing preliminary dismantling. To gain access to them you must remove the interior body pieces. If memory serves me correctly you have to start by removing the metal scuff plates first. Continue removing the interior parts one at a time until the inside back panels are off. You will then be able to access the sheet metal screws holding the exterior molding on. Quote Link to comment Share on other sites More sharing options...
terrya Posted August 31, 2009 Author Share Posted August 31, 2009 Thanks for the reply, wish I knew that last week. I had all the back interior out for other things, then took a good day fighting to get it all back together. There's no way I'm ready to go thru that again I'll keep this in mind for later. For now I'll just try to work around it. Quote Link to comment Share on other sites More sharing options...
datsun79z Posted August 31, 2009 Share Posted August 31, 2009 Terrya The interior comes out easier each time it is removed. I know. I've removed mine 3 times. Quote Link to comment Share on other sites More sharing options...
