nazgule6 Posted August 21, 2009 Share Posted August 21, 2009 imm still confused about converting the 280z stock headlights into hid? do i have to upgrade the wiring harness for the conversion or can i just buy a hid kit and plug and play...also what kind of bulb housing would fit for the conversion..i think h4 will work but im not sure? any info is appreciated thanks.... Quote Link to comment Share on other sites More sharing options...
zedman240 Posted August 21, 2009 Share Posted August 21, 2009 (edited) I've been thinking about doing an HID installation but a few things have to be thought out first. I do have a Hella ballast and HID globe with a H4 base but if you have an H4 insert without a light shield, you will annoy oncoming drivers. Plus, with my setup anyway, you will have to butcher the original headlight buckets by cutting a pretty big hole in the back and then having to make it weather proof. You will have to do some wiring unless the kit you want to buy comes with a pre assembled loom. HID systems do take a lot of current on startup (around 20 amps) then drop off to around 3-4 so you will have to install a realy. A zed light switch WILL melt at that current. I've heard of many different types of conversions so just do heaps of research and find a good one. With some conversions you do lose high beam! Edited August 21, 2009 by zedman240 left out a word! Quote Link to comment Share on other sites More sharing options...
