Z32 Gear Ratios
Matt z32
  • Administrators
I'm just looking for any insight or opinions as to what would be an ideal ratio set up for added torque and hook-up.
Gear ratios will NOT increase torque, they will however trade shaft RPM for torque. Or, (depending on what you meant by your question), different "ratios" are not necessarily required if your engine is producing "added torque". shrug.gif
Your driving habits, the engines power curve, intended usage, vehicle weight etc, will have a significant influence on what the "ideal" ratio or ratios would be for your application. Your initial question is just to vague.
Added hook up? Tires with better traction will provide more hook up regardless if you “added torque” or not! scratch.gif
