Cam help For TPI
im looking at this cam comp cams 12-210-2 would this be good in my z its got a 350 TPI and a nv3500 out of a late 80s truck and the stock manual trans rear end and 195/75/14 tire this is the cam specs that im looking at
RPM 1500-5500 Duration 268/268 and lift is 454/454 this is seat to seat duration @0.050 is 218/218 and lobe center angle is 110 any info would be great thanks
having build a good many tpi engines I think you'll benefit from a wider 112-114 LSA and limit duration to about 215-218 intake duration
example
E110030K
http://www.pbm-erson.com/store.php?catId=334&parent=333&grandparent=327
http://forum.grumpysperformance.com/viewtopic.php?f=55&t=1509
the main reason is that the factory sensors that control the fuel/air ratios don,t work well with reversion pulses in the intake that ,overlap in the cam lobes timing can cause ,increased duration, and tighter lsa angles tends to increase the overlap and cause problems with the stock tuning cpu
Edited by grumpyvette
That cam would work well with a 4 bbl intake and holley. Your manual trans is a plus for that cam (no stock converter).
I would use a more mild efi cam from compcams. Like 206 to 212 on the intake at 0.050" and 6 to 10 degrees more on the the exhaust (compared to the intake) then use 114 LSA with efi.
If you really want to make more power, then swap over to vortec heads and intake. Should pick up 50hp with that swap. Then maybe another 30 or 40 with a mild cam and exhaust swap. 300hp is with in reach.
