slowz33 Posted August 31, 2009 Share Posted August 31, 2009 I started my swap this weekend, not useing any kit just making custom parts to do it. I'm using a 5.3 and going with a TH350. I'll keep this updated as I get more done but it will be slow going as I don't have much time to work on it. Quote Link to comment Share on other sites More sharing options...
qwik240z Posted September 14, 2009 Share Posted September 14, 2009 Good Luck with the project. You will be much better off finding an overdrive trans. You will find out what a mistake you made on the first drive if you stick with the TH350 trans. Find a 4L60E and go with that. It is meant to go with that motor and your car will not be a buzzmobile on the hwy. Quote Link to comment Share on other sites More sharing options...
slowz33 Posted September 21, 2009 Author Share Posted September 21, 2009 Good Luck with the project. You will be much better off finding an overdrive trans. You will find out what a mistake you made on the first drive if you stick with the TH350 trans. Find a 4L60E and go with that. It is meant to go with that motor and your car will not be a buzzmobile on the hwy. its going to be on the drag strip more then the Hwy so it should be ok. I run a 28" tall tire and the stock 3.55 rear gear. Quote Link to comment Share on other sites More sharing options...
slowz33 Posted September 21, 2009 Author Share Posted September 21, 2009 got some work done this weekend Stock GTO motor mounts the TH350 fits good and I'll be able to use my stock trans crossmember also Quote Link to comment Share on other sites More sharing options...
