found a 327.. but...
I believe the only difference was the heads and cam and compression difference, not sure if the compression difference was done with smaller chambers or pistons though, some of the 327's had 11 - 1 compression (I believe it was the 1966's at like 365 gross HP). These days its hard to be real choosy in my opinion about finding 327's. Easy to fix any
way.
Regards,
Lone
Guest Night_rider_383
bumble zee... ditto to what long and davyz said. I really don't see the point in looking at stock hp. It means nothing unless your doing a numbers matching restore cause all of us its gonna do some kinda of a mod to our engines right. Long was right the bigg diff. in the higher and lower hp engines was the heads, cam and compression. Lower hp 327's ran the power pak heads while the higher ones had the double hump heads.
