fuel pump wiring
ok the engine is in the car and running. the wiring is about 90% finished with the exception of the taurus fan and the fuel pump. i used the dodge fuel pump switch and i am having a problem with the jumper that powers the pump while cranking. i am using a ford solenoid, does the wire go to the small post? thanks guys for all the help rick
Do you have the JTR manual? I am at the same point as you. I have looked at the suggested wiring in the manual and am confused. I am not sure what starter is on the car since we bought a running car and have had to completely rewire the car. It was a show car and the wiring was really buchered. We removed all wiring and rewired with a 1983 wiring harness.
I will have my son work on the wiring this weekend and let you know how we come out.
We are having a problem with the tach wiring. There is a resistor between the tach and the distributor. We can not find it.
