brnin8r Posted September 8, 2009 Share Posted September 8, 2009 Hi all, The noob again. Can anyone identify these headers? I have the angle plug fuelie heads (double hump) and wondered if I could replace these headers, and do short plugs and not have the "dings" in them? Is much flow lost from these "dings" to clear the angle plugs? Are there other (better) headers I can use that will fit these angle plug heads, the 240z, and still have the collectors at the same place so I can use my existing exhaust? Or.... should I just clean these up and keep using them (are they decent)? Thanks again - love Hybridz! Quote Link to comment Share on other sites More sharing options...
5litre z31 Posted September 8, 2009 Share Posted September 8, 2009 Hi those headers look like a set of stanard block hugers I have just removed from my z and replaced with a custom set along with a full 3 inch system made a big difference not cheap but worth it. Quote Link to comment Share on other sites More sharing options...
Scarab 155 Posted September 8, 2009 Share Posted September 8, 2009 Sanderson makes a set of block hugger headers that clear angle plug heads. The outer tubes overlap the inner tubes (the opposite of your headers) and clear the plugs. I'm not sure, but they may line up with the reat of your exhaust as is. Scarab 155 Quote Link to comment Share on other sites More sharing options...
brnin8r Posted September 9, 2009 Author Share Posted September 9, 2009 Thanks again. Sanderson has quite a few choices of block huggers, so looks like I'll have to do some measuring. I'd like to just do a bolt-in, so hopefully I can find some headers that line up (rest of my exhaust is in ok shape - looks like it was stainless and single chamber flowmasters). Quote Link to comment Share on other sites More sharing options...
