hiromino Posted April 9, 2002 Share Posted April 9, 2002 hi. last night i drove back from work. when i got home i turned the key to stop the car. however, what happned was the key turned but the engine didn't stop. and i couldn't turn the key back,the key turns clockwise but as if i am trying to start the car(to run starter). so i had to disconnect the battery in order to stop the car. i can start the car just connecting the battery and starting the starter. i don't know how to explain this situation. anyone had similar experience? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 9, 2002 Share Posted April 9, 2002 Your ignition switch maybe shot or froze up. If you have access to another ignition switch- Try it and see if it works properly. IF NOT- Disconnect the wiring harness terminal to the ignition switch and "hot wire" the ignition wireing. Connecting the right two of the five wires will turn the ignition on and a third wire when momentarily touching the connected "on" will engage the starter. I always keep a spare ignition switch for emergencies. Quote Link to comment Share on other sites More sharing options...
hiromino Posted April 10, 2002 Author Share Posted April 10, 2002 thank you! i fixed the problem by hitting the ignition key by hummer for couple times. as you said probably the ignition key is broken, i guess better change it asap. thank you ! Quote Link to comment Share on other sites More sharing options...
