Guest Anonymous Posted April 17, 2002 Share Posted April 17, 2002 Thanks Jeff, I got the switch today in the mail (nice... it'll be so nice compared to that screwed up POS thats in there) and I opened and saw the screws your talking about, its like a hex head deal that is designed to break off when its tight and leave that flat head your talking about. Thanks on the drilling idea, be easiest since it doesn't need to go back on ever (and after I slam it in the ground a couple dozen times it couldn't anyway). Thanks and regards, Lone Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted April 17, 2002 Share Posted April 17, 2002 I have ordered a new ignition switch/lock/key assembly as mine was badly worn out. Are there any tips before I take a stab and then lose my mind in anger over something stupid I hadn't expected. So, any tips, is this a one or two six pack job? , Lone Quote Link to comment Share on other sites More sharing options...
Guest jcp240z Posted April 17, 2002 Share Posted April 17, 2002 The easiest way is to use a cutting wheel on a dremel and put a slot in both heads. Then you can use a standard screwdriver and just unscrew them. The surrounding metal will be notched also. No bid deal, especially since you have new ones. Quote Link to comment Share on other sites More sharing options...
Jeff Posted April 17, 2002 Share Posted April 17, 2002 Once you have removed the plastic steering column cover you can get to it fairly easy. There are four screws that hold the switch to the column, it clamps around the column. The trick is that two of screw heads are smooth, no slot for a screwdriver. These must be drilled out very carefully, just go slow. Once you have the switch in hand the remainder of the screw comes out easily. Hope I haven't confused you, but you'll see what I mean when you get into it. Best of luck. Quote Link to comment Share on other sites More sharing options...
