Guest Anonymous Posted May 18, 2002 Share Posted May 18, 2002 I'm getting ready to do the camaro radiator instal, however I was just told by the chevy dealer today that the bushings and upper radiator bracket for the 84 have been discontinued. I already have the JTR lower bracket but am somewhat stuck at this point. I need bolt on so the options with custom fabrication and welding are out. In the posts I searched through people mentined getting the upper bracket at summitracing, but all I find there are 2 to choose from and they are both listed as pre 80 vehicles. Anyone have part#'s or more info on the parts, both stock chevy and summit? thanks in advance for any info you can provide. Trevor Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted May 18, 2002 Share Posted May 18, 2002 All '82-'92 Camaros/Firebirds are the same "F" body car. That same part will mostly likely be available on a newer year car. Quote Link to comment Share on other sites More sharing options...
dmanzo57 Posted May 18, 2002 Share Posted May 18, 2002 I used Summit PN: SUM-G3922. It fit perfectly. Don Quote Link to comment Share on other sites More sharing options...
Tim240z Posted May 18, 2002 Share Posted May 18, 2002 ta, I used the cowling and fan from a camaro which has the rubber pads that hold the rad at the top incorporated in it. I just drilled some holes in the top of the radiator mount panel of the Z and mounted it. Holds it very firmly. Think I have pics on my site. Tim Quote Link to comment Share on other sites More sharing options...
BLKMGK Posted May 18, 2002 Share Posted May 18, 2002 I don't have that radiator but... I used some aluminum strap that was welded to look sort of like an F. For pads I used the S-10 pads the JTR book talks about. Those are SWEET and made of what looks like urethane. Cheap too Quote Link to comment Share on other sites More sharing options...
