Automatic AC's on the 280zx's friggen suck!
ratedZ
Are there any other 280zx owners who has been blessed with the not so automatic AC systems in their Z's? I wanted to know if your guys' heater only blow through the floor vents and defrost. For as long as I have owned mine I can't figure out why the heater won't blow through the front vents. AC works fine (I could blow harder through a straw but that's a whole nother subject) and it blows through the front vents like it's supposed to be. Did Datsun do this on purpose? If I remember correctly when I had an 82 turbo back when I was 16 it did the same exact thing so I'm wondering if that's the way it's supposed to me. If it is, I wish I knew who's bright idea it was so I could smack them in the back of the head malebitchslap.gif
ps. i don't need the heater right now as it's a 106 in Vegas but might as well ask to get it ready for the winter season ;)
I just got an 82 turbo auto (my 1st auto) and under any kinda acceleration, the ac switches to the floor vents until a steady rpm is attained, then it comes back out of the normal vents. I can't orate on the heat issue though.
I'm not sure if it is cutting the ac off under accel or just a vacuum anomaly in my car. It stays cool, but could just be residual in the system.
Guest Aaron
ZX's used vacuum to move the flapper thing that makes the air come out the defrost/dash/floor. (I hope everyone can keep up with the high tech mumbo jumbo. smile.gif ) They were notorious with the datsun mechanics for having vacuum leaks, etc., that would make the air come out in undesired locations. The turbos were much worse than the N/As. While I believe the heat not coming out of the dash is by design, changing where it comes out during acceleration is caused from vacuum leaks or bad vacuum canisters. I was going to install a vacuum pump on my ZX in high school, but never got arount to it.
