JSM Posted October 10, 2009 Share Posted October 10, 2009 The rear brakes are absolute trash and I dont want to spend any money on the car. Can I simply block off the main line from the MC going to the rear and have just front brakes only? Is there a simpler way? I got the motor running in this parts car and now I want to see if the trans is any good. I'd like to keep the trans as a spare. Quote Link to comment Share on other sites More sharing options...
hoov100 Posted October 10, 2009 Share Posted October 10, 2009 just crimp/smash the lines until theirs no pressure getting passed it Quote Link to comment Share on other sites More sharing options...
JSM Posted October 10, 2009 Author Share Posted October 10, 2009 just crimp/smash the lines until theirs no pressure getting passed it The line off the MC to the rear right? I don't recall if there is a proportioning valve in the ZX or not but it should not impact anything? Quote Link to comment Share on other sites More sharing options...
hunterzed Posted October 10, 2009 Share Posted October 10, 2009 Don't crimp or smash the hard line. You might burst it and that would create more problems cause you'd have no brakes at all and you might want to use the brake line at a later date. Just get some vice grips and crimp the flex lines to the wheels and then just tie them up out of the way with plastic zip ties. Old school line locker setup for burnouts. Quote Link to comment Share on other sites More sharing options...
JSM Posted October 10, 2009 Author Share Posted October 10, 2009 Don't crimp or smash the hard line. You might burst it and that would create more problems cause you'd have no brakes at all and you might want to use the brake line at a later date. Just get some vice grips and crimp the flex lines to the wheels and then just tie them up out of the way with plastic zip ties. Old school line locker setup for burnouts. There are no rear soft lines! The soft lines have rotted away and the hard lines are rusted tight. (I already snapped a rear hard line.) I have no title and the car is a rust bucket. She will be cut up... Quote Link to comment Share on other sites More sharing options...
hunterzed Posted October 10, 2009 Share Posted October 10, 2009 How have you got any brake pressure at all to the front then if you don't have any lines to the rear? The whole system is connected. Quote Link to comment Share on other sites More sharing options...
JSM Posted October 10, 2009 Author Share Posted October 10, 2009 How have you got any brake pressure at all to the front then if you don't have any lines to the rear? The whole system is connected. I don't. The front barely dribbles out, the rear was doing nothing until I realized the soft lines were off. I was trying to bleed the whole system and couldn't figure out why no fluid was moving to the rears. Quote Link to comment Share on other sites More sharing options...
JSM Posted October 10, 2009 Author Share Posted October 10, 2009 I'm thinking that it would be better to crimp the line after the NP - valve, proportioning valve, as to not lose any fluid via the valve to the rear. Thoughts? Quote Link to comment Share on other sites More sharing options...
Nigel Posted October 10, 2009 Share Posted October 10, 2009 How have you got any brake pressure at all to the front then if you don't have any lines to the rear? The whole system is connected. Please explain what you mean when you say the whole system is connected? Typically the front and rear circuits are isolated from each other (even when they share the same reservoir). Nigel '73 240ZT Quote Link to comment Share on other sites More sharing options...
hunterzed Posted October 10, 2009 Share Posted October 10, 2009 What I mean by this is that when you try and bleed your brakes all the fluid will flow out of any of the brake lines that are open and the reservoir will empty leaving no fluid for the other brakes. Hence connected. Quote Link to comment Share on other sites More sharing options...
GLENN280ZX Posted October 10, 2009 Share Posted October 10, 2009 Let us know how your first ride on a wet day goes!! Quote Link to comment Share on other sites More sharing options...
