usafdarkhorse Posted October 17, 2009 Share Posted October 17, 2009 I've had my 75 Z for 6 months now and the entire time I've not had turn signals ( like my 76 Z before ) and it KILLED ME. So this weekend I decided to tackle the issue. Here were my symptoms before: All hazards except front right blink, no turn signals at all. Every parking light is lit. I ended up taking apart the hazard switch and cleaning it, purchasing a newer generic flasher relay, and taking apart the turn signal switch and cleaning it. I followed a few helpful threads here and got some good advice toward the likely candidates that might be causing my problems. Afterward, my symptoms were these: All hazards except front right blink, all turn signals except front right blink. Every parking light is lit. Seeing a connection here? Anyway, everything is MUCH better now, but I still cannot manage to get my right blinker to flash. I didn't think the bulb was bad, but I changed it out anyway ( no telling how old it was ) and it was still a no-go. Keep in mind that my front right PARKING light is fine, but the actual FLASHING is not. It will go out when I turn on the hazard switch. Anyone have any idea about how I can negotiate a legal right hand turn? Locations of grounds and important items through the circuit would be immensely helpful. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
280Z-75 Posted October 19, 2009 Share Posted October 19, 2009 I've had my 75 Z for 6 months now and the entire time I've not had turn signals ( like my 76 Z before ) and it KILLED ME. So this weekend I decided to tackle the issue. Here were my symptoms before: All hazards except front right blink, no turn signals at all. Every parking light is lit. I ended up taking apart the hazard switch and cleaning it, purchasing a newer generic flasher relay, and taking apart the turn signal switch and cleaning it. I followed a few helpful threads here and got some good advice toward the likely candidates that might be causing my problems. Afterward, my symptoms were these: All hazards except front right blink, all turn signals except front right blink. Every parking light is lit. Seeing a connection here? Anyway, everything is MUCH better now, but I still cannot manage to get my right blinker to flash. I didn't think the bulb was bad, but I changed it out anyway ( no telling how old it was ) and it was still a no-go. Keep in mind that my front right PARKING light is fine, but the actual FLASHING is not. It will go out when I turn on the hazard switch. Anyone have any idea about how I can negotiate a legal right hand turn? Locations of grounds and important items through the circuit would be immensely helpful. Thanks in advance! could be your switch. Quote Link to comment Share on other sites More sharing options...
usafdarkhorse Posted October 19, 2009 Author Share Posted October 19, 2009 I actually resolved this on Saturday. I ended up taking apart the hazard switch and the turn signal switch as well as buying a newer generic flasher unit. I got all signals but the front right and I found out the flasher circuit had sunk into the connector ( should be 3 prongs, I had only 2! ). Pulled out the wire, reconnected, good as new. Thanks all! Quote Link to comment Share on other sites More sharing options...
