Cleaning up an engine Bay
My first plan of action after getting my new z is cleaning and derusting the engine bay and respraying it. Besides sand paper, degreaser and a ton of elbow grease, anything else i should keep in mind to help the process? I was thinking about something like this, but im not sure if its overkill or not
http://www.sears.com/shc/s/p_10153_12605_00961090000P?vName=Tools&cName=Portable+Power+Tools&sName=View+All
If you have the ability to yank the motor and clean the WHOLE engine bay, I would do it if I were you. Otherwise, degreaser, elbow grease and a ton of soap and water will be sufficient. If it's rusty/damaged, the dremel kit may be a worthy purchase if you don't have an angle/disc grinder, which is what I used.
Try seeing if your neighbours have a dremel tool kit before you go out and purchase one :P
Best of luck!!
DK1
