Jefferson71 Posted October 25, 2009 Share Posted October 25, 2009 I have had my current 71 for 10 years. I swapped the automatic for a 5 speed about 5 years ago and swapped the engine to a p79 2.8 about 5 months ago. I clean-up the head and had a valve job done (shaved about 2 thousands) otherwise stock. It had decent power when installed. 2 weeks ago I did a cap, rotor and plugs and now it has no power under anything but about 1/8th throttle. Here are the stats: P79 w/ new z-therapy carbs (sm needles) - decent in car tune running a stock mechanical fuel pump using a zx e12-80 distributor - blaster 2 coil MSA 2.5 inch exhaust (fairly new) compression is 180-185 across all 6 16-17 vacuum at idle fuel is 2.8 psi at idle around 3.1 at higher revs. So far, I think I have done the obvious. swapped back the old plugs (all were ngk's) new ones gapped at .045 swapped back old cap & rotor got a new wire set swapped the fuel filter adjusted the valves swapped in my back-up distributor w/different module None of these things made any difference. The plugs look ok, one had carbon deposits. Cleaned them and verified spark. I am not sure what to do next, any suggestions would be greatly appreciated. thanks Quote Link to comment Share on other sites More sharing options...
Jefferson71 Posted October 31, 2009 Author Share Posted October 31, 2009 Turned out to be an easy fix. The fuel line between the carb & fuel bowl on the front carb had a kink in it. Quote Link to comment Share on other sites More sharing options...
