Guest Paul Felker Posted August 13, 2002 Share Posted August 13, 2002 does anybody know the wires on these tachs, and how to hook it up i got the lights to go on and dim also but where do i hook the red and green to this car still has the stock ignition in it so please tell me how to hook it up please. also for a six cylinder car arnt you supposed to cut one of the loops on the back also? there are two loops on the back one brown and orange? i think those are the colors. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 14, 2002 Share Posted August 14, 2002 Looking on my 240: red:ign. power green: coil- And I also had to cut a brown wire for 6cyl. operation. For 8cyl. DO NOT cut brown wire on bach of Tach. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 14, 2002 Share Posted August 14, 2002 Cont: as for the orange wire: ONLY CUT for 4CYL. for 6 or 8cyl DO NOT cut orange wire. Quote Link to comment Share on other sites More sharing options...
Guest Paul Felker Posted August 14, 2002 Share Posted August 14, 2002 the green wire goes to the positive side of the coil correct? this car(78z) has all the stock ignition stuff in it right now, so i hook the green wire to the pos. side of the coil and the red ot a switched power source and i'm in business right. what is this i hear about the car not starting wihtout the stock tach? and what are thesr tach adaptors like the msd#8920 i hear that Some cars need? thanks for the reply!! Quote Link to comment Share on other sites More sharing options...
Guest Paul Felker Posted August 14, 2002 Share Posted August 14, 2002 so just cut the brown wire only for 6 cylinder car to get the tack working correctly??? Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 14, 2002 Share Posted August 14, 2002 Actualy the green wire goes to NEG. coil terminal. As for the car not starting: I had that problem when I installed Crane Cam's ignition box on my 240. Apparently something about the old style tachs not working with the new style ignition (replacing the points) My buddies car did the same thing with MSD's kit. I believe the MSD part # you're talking about is to make an MSD ignition compatible with fuel injection, but I'm not sure. Either way if you have a new autometer tach your car should run just fine with stock or aftermarket ignition. Good luck. Quote Link to comment Share on other sites More sharing options...
jaime240z Posted August 14, 2002 Share Posted August 14, 2002 Yes for 6cyl. operation- red: 12v pwr green: NEG. ign. coil brown loop: cut and tape ends orange loop: leave it alone Quote Link to comment Share on other sites More sharing options...
