Problem getting it to fire - please check my MSQ
trwebb26
Just finished adding a turbo and replacing the injectors with 440cc supra ones. I'm getting good spark when I'm supposed to be (says the timing light) and I've pulled plugs and they are wet with fuel, but I can't get it to light off... not even a sputter. My first instinct is to replace the plugs, but I wanted you guys to check out my MSQ, please.
The car was running on megasquirt before I did the swap.
Stock 78' N/A block and head
Holset HE351 turbo
MSD2 ignition running L28ET dizzy. I see RPMs in Megatune when I crank.
All of the sensors are reading correctly and I know I'm getting spark at the plug wires
Injectors are 440cc supra ones (brand new).
megasquirt200910272131.zip
  • 1 year later...
